blu260z Posted September 6, 2015 Posted September 6, 2015 Hey guys is there a gasket behind the timing chain tensioner. For the life of me I cant remember if there was one when I pulled it off and I cant see one in the full engine kit I purchased. Quote
GongZ Posted September 6, 2015 Posted September 6, 2015 (edited) According to the following discussions about this on classiczcars and zar.com, there was a gasket fitted to the cars when they were made, but - "It seals metal to metal........Nissan recognized this and quit supplying gaskets years ago. Don't use anything. Just bolt it up and torque to spec." Another response adds - "A THIN, LIGHT coat of sealer works great" And Phred (classiczcars) reckons - "Agreed! No gasket needed. However, I always make sure there are no burrs on the tensioner face. A piece of 400 wet sand paper on a hunk of glass, and work the the contact area lightly. A nice smooth surface will seal up great. And if it does leak a bit?!!! OMG, some oil will get inside your timing cover! Cheers!" http://www.classiczcars.com/topic/42690-gasket-for-timing-chain-tensioner/ http://www.zcar.com/forum/10-70-83-tech-discussion-forum/125822-timing-chain-tensioner.html Edited September 6, 2015 by GongZ Quote
blu260z Posted September 6, 2015 Author Posted September 6, 2015 According to the following discussions about this on classiczcars and zar.com, there was a gasket fitted to the cars when they were made, but - "It seals metal to metal........Nissan recognized this and quit supplying gaskets years ago. Don't use anything. Just bolt it up and torque to spec." Another response adds - "A THIN, LIGHT coat of sealer works great" And Phred (classiczcars) reckons - "Agreed! No gasket needed. However, I always make sure there are no burrs on the tensioner face. A piece of 400 wet sand paper on a hunk of glass, and work the the contact area lightly. A nice smooth surface will seal up great. And if it does leak a bit?!!! OMG, some oil will get inside your timing cover! Cheers!" http://www.classiczcars.com/topic/42690-gasket-for-timing-chain-tensioner/ http://www.zcar.com/forum/10-70-83-tech-discussion-forum/125822-timing-chain-tensioner.html Thanks mate ☺ Quote
