Posted (edited)
Hi Peter,
Does the 100 g per rod saving with the spool rods compared to standard make any difference to engine acceleration?
Also what do you consider rpm limit of cast pistons?
Edited by Blue Z
Hi Peter,
Thanks, I will stick with the standard rods and cast pistons. If I had a spare 2k then I would do the spool rods and forged pistons.
Cheers James
  • 1 month later...
Chinese rods!, even if your HP required new rods , I would go for tried and "tested" rods, sure they might look the goods, but let someone else be the 1/1000 person that they let go on. As Peter said the stock rod is fine , I am using a prepped stock l24 in my turbo stroker for a very reliable 450hp.
