Suit Dato 1600 or aSunny, or Stanza, where the shorter type gearbox is needed.
Ideal for a SR conversion.
Current ratio set is std, but I can fit a Close Ratio set.
Fifth gear is the better 0.83!
Ot has the bigger gears, better selector forks, as found in SR and RB boxes.
Comes with a RB or a SR bellhousing.
You supply ke a L bellhousing, I'lll get it machined and fitted.
$450
NB, a Stumpy box is AKA a MR30 or R30 short extension hsg length box, but in MR and R model is a B type
