Magnet Posted March 8, 2015 Posted March 8, 2015 Bought this elec dizzy off ebay, meant to be off R30, getting no spark. Numbers are D6K9-05 5104 22100 S6706 I'm no wiring expert so i'll just tell you what i'm getting; 12v+ at both positive and neg terminals at coil 1.2v from both wires going from module to dizzy I've attached a photo, let me know if something looks wrong/missing Cheers Quote
WogsRus Posted March 14, 2015 Posted March 14, 2015 this should help http://datsunzgarage.com/engine/ Quote
Magnet Posted March 17, 2015 Author Posted March 17, 2015 No dice, tried everything Think the module's rooted Quote
chris240 Posted March 17, 2015 Posted March 17, 2015 Have you gone thru the pics and descriptions under elec dizzy upgrade which is sticky'd under the electrics postings ? Quote
Retro Z Posted March 17, 2015 Posted March 17, 2015 The red and green wires from inside the dizzy i had connected to the 2 connectors on the inside part of the module. With the red wire/connecter being closer to the cam cover and the green further away. I then just ran 2 new wires, one being a 12v+ and the other a earth directly from the coil directly to the 'L' male connectors on top of the module. I had this method work with both the ballast resistor and without. So on my coil i have a Black/white wire going to + and a solid black on the earth. Green and another black/white at the ballast resister which i have now bridged. If you bridge the wrong black/white wire with the green you will not get power to the coil. I've attached a diagram similar to what ive done. Quote
