phillay Posted September 23, 2014 Posted September 23, 2014 selling an injection parts off an L28 so I have 2 sets of inlet manifolds, both with fuel rails and injectors. one has all the emission gear removed and one hasn't $150 each I have a surge tank with the associated lift pump and high pressure fuel pump - $80 for that. and ems stinger 4424 ecu that was used to run the injection, it has a map sensor built in, requires a loom plug though which you can buy from ems themselves. - 200 pick up from braybrook or cairnlea or shipped at your expense cheers Quote
