dat2kman Posted June 25, 2014 Posted June 25, 2014 Suits L26 and L28 bottom ends. Pro made in USA, as used in many performance use cars. This bolts via mains cap bolts, and is designed to keep oil from being whipped up, and puts it back where it should be, the sump. Thats why it improves horsepiwer, the crank has free air to spin in! Brand new. The leading edge is razor sharp! It can even be fitted with engine still in the car, as you do not remove the mains caps, just one bolt per ! $150 Can pack&post. Quote
