zed4ps Posted February 19, 2014 Posted February 19, 2014 WOOPS: Was playing with the air flow meter on my series 1 l28 efi engine when, you guessed it, i let go of the spring. Anyone know of a way to reset the spring back to a starting point of which i can then advance to a better setting? Any help would be appreciated. ( Things we learn as we play with our cars ) Cheers Peter Quote
dat2kman Posted February 23, 2014 Posted February 23, 2014 Get another one, from wreckers, prise black cover off and "feel" for the correct amount of tension/force is required to push flap door. Duplicate by winding more/less. You will definately know if too tight, too loose is a bit harder to feel. There will for sure be some grams per millimetre figure to set it to, in a workshop manual, but try getting the correct equipment to do so! Quote
