44014 Posted December 6, 2013 Posted December 6, 2013 LT12S The LT12S has 6 injector driver, 6 ignition driver ECU with multiple Auxiliary inputs and outputs. Most often used on 6 cyl and 3 rotor applications but also can be configured for 4 cyl vehicles. Condition is used but very good condition. Comes with loom can be adapted to any vehicle. $650.00 Quote
pauly_adams Posted December 7, 2013 Posted December 7, 2013 what does the ignition run off, if I had the cash It would be mine right now. now ill have to sell some more gear Quote
44014 Posted December 7, 2013 Author Posted December 7, 2013 One of these. http://www.xtremeautoparts.com.au/shop/pc/viewPrd.asp?idproduct=1766#.UqMh938aySM Or you could spend alooot more and get one of these. http://www.ebay.com.au/itm/M-W-Pro-16B-CDI-Ignition-System-MicroTech-6-Cyl-Race-Efi-/290724022797?pt=Motors_Car_Truck_Parts_Accessories&hash=item43b0808a0d&_uhb=1 Or even a set of these http://www.ebay.com.au/itm/Smart-high-output-coil-spark-plug-wire-6-cyl-kit-NO-IGNITER-REQUIRED-/110991565133?pt=Motors_Car_Truck_Parts_Accessories&hash=item19d79ce14d&_uhb=1 Cheers Doug Quote
Mr260z Posted December 8, 2013 Posted December 8, 2013 This kinda stuffs out of my league but to those that know my car , do I want this? And why? Fuel injected l28 and to my understanding its running the standard 280zx computer. Thanks Joel Quote
44014 Posted December 8, 2013 Author Posted December 8, 2013 The microtech x6 is only $150.00 brand new that will fire 6 standard coils. Or you could just use it to run the fuel side of things and use the electronic ignition on the engine. Quote
