tir33d Posted December 6, 2013 Posted December 6, 2013 Well I have sitting here a set of 2 way adjustable coilovers that haven't been fitted or butchered. Brand name is Ceika (ceikaperformance.com). Type 2m set. I have decided to move these along as I don't think they are going to be right for my application. I waited a couple of months for production, then received them only to find they were suited to a 240/260/280. PCD on towers too small. The owner Cedric apologised and sent me the right tops and also a couple of legs for the rears...... Then it gets awry..... Been trying to contact them again now for 2-3 weeks and yet to receive a response. My problem was I wanted to disconnect the pipework to the canister to fit new legs. This proves to be a problem caused you will let all the secret stuff out...... So we were about to start macgiver-ing a solution as im finally ready to start assembly and we came across a rather large problem. I know the height I want, I have coilovers already from the last car, I know my distances. These shock bodies are too long for my needs. A road car should have no problem, but my dedicated track use is the problem. I want 100mm and that's it. It looks as if I am going to try to recoup some cash and fix / upgrade my ksport coilovers. (Bloke at AB imports was really helpful). These shocks owe me $1800 as they stand, you will have to weld your legs / engineer them. I can measure anything you need. Spring rates are heavy at 10kg front 12 rear. Offers or interest??? Quote
tir33d Posted December 6, 2013 Author Posted December 6, 2013 Second last photo and last photo show my issue. The car is close to height I want, but the distance measurement is 500mm front strut top to bottom at the moment. For me to lower any further I need a smaller number. The hose hanging from the bottom will not allow me to get any lower. I need a slightly shorter shock body. Quote
44014 Posted December 7, 2013 Posted December 7, 2013 Hi there, so those silver metal sleeves does the shock body screw into those ? If this is the case can you not just shorted those sleeves a bit? Quote
44014 Posted December 7, 2013 Posted December 7, 2013 Oh and do you still have the 240/260 strut tops ? Quote
tir33d Posted December 7, 2013 Author Posted December 7, 2013 Photo 4 shows where I would need my eyelit, next line up is the shock inside the body, there is a straight fitting off the bottom of shock, the line will distort to far to get to my height. I believe they are 240/260 mounts in the photo. Quote
44014 Posted December 7, 2013 Posted December 7, 2013 Are 280zx struts shorter then 240/260 ? Seriously considering them just don't want to get into the same situation as your self and be able to get it low enough. Quote
tir33d Posted December 7, 2013 Author Posted December 7, 2013 Tape measure is your best friend. I am not rich enough to own a 240/260. Quote
44014 Posted December 7, 2013 Posted December 7, 2013 Fair enough. Do you have the measurements for the 280zx struts Cheers Doug Quote
44014 Posted December 7, 2013 Posted December 7, 2013 Actually, can I just get the measurement of the coil overs. Total length and I'll see what I can figure out . Quote
tir33d Posted December 8, 2013 Author Posted December 8, 2013 500mm from top ofcamber plate to eyelit would be the minimum on all four struts Quote
