z31(L) Posted October 20, 2013 Posted October 20, 2013 So just decided to edit a previous thread instead of flooding the forum with new threads. Hopefully there's some more z31 guys on this forum. - I have the front 5 stud suspension out of my Californian model z31, it has the good floating rotor style brake and hub setup, 4 pot s15 brakes included. The geometry on this suspension is slightly revised so better if you're planning on tracking your z31. Includes everything under the front wheel arch; control arms, struts, s15 brakes, lines, castor rods, tie rods etc. $700 ono. Hubs bolt straight into hr31's too for an easy 5 stud and big brake conversion. SOLD - Rear 5 stud, comes with vented rotors (which the older models didn't have), callipers, control arms, handbrake cables etc. Has slightly wider track than the earlier models iirc. $200 ono. SOLD Or the lot front and rear for $800. SOLD - LSD diff SOLD - Also have another open r200 diff (3.54 ratio) and a pair of 4 bolt turbo half shafts to suit, seems to all be in good nick, but haven't used it, $350. SOLD - vg30et engine, doesn't start on it's own, but runs on aerostart, has been rebuilt 15k ago according to the old lady that used to own it but no receipts. Was in front of an auto so hasn't had a hard life; Comes with everything including loom, auto box, starter and engine mounts. $200. Maybe good for a conversion? SOLD - Stock z31 16" wheels, hard to get them in 16" as most came with 15's. Suit someone restoring one. Has 80% front tread and around 50% rear. $150 SOLD - Also have a full brown leather interior, if you need anything make an offer and we'll go from there. Located South Brisbane, 0421 287 390, text preferred. Cheers. Quote
z31(L) Posted October 24, 2013 Author Posted October 24, 2013 Daedalus-Z, I have an open r200 longnose sitting here, I'll check the ratio and if it's 3.9 I'll pm you! Quote
Daedalus-Z Posted October 25, 2013 Posted October 25, 2013 Thanks mate! Might be interested in those CV shafts too. Just need to finish doing some reading on them. Quote
