I may have to get a tow truck in to move redzed tomorrow so I had a look under the car to see where the truck winch would attach to drag her up the tilt tray. If we pull her from the two front tow eyes the air dam, scoop will get shredded and there are no tow points at the back. Is it OK to attach the wire to a rear control arm and put a few layers of carpet between the wire and fuel tank ...........or is there a better way at short notice??
Mickl
Front engine crossmember, rear diff or just remove the airdam. I wouldn't pull from the rear control arm.
Thanks for the advice retro z, I didn`t think to remove the spoiler, it only took a few minutes to pull it off and gat it loaded up on the truck.
Mickl
