imackz Posted April 14, 2013 Posted April 14, 2013 If anyone is wrecking a early series 1 (1979) 280zx would like the intermittent wiper amp , nissan part # 28890-P7100 regards Iain as per below: Quote
dat2kman Posted May 2, 2013 Posted May 2, 2013 I have boxes of electrical bits, describe its size, how many pins etc.? Any other markings? Quote
imackz Posted May 2, 2013 Author Posted May 2, 2013 where is it? what does it look like? Located in a recess near the brake booster there is usually a plastic cover, and 2 relay lloking devices, 1 is the horn relay the other is the intermittent wiper amp Quote
imackz Posted May 2, 2013 Author Posted May 2, 2013 I have boxes of electrical bits, describe its size, how many pins etc.? Any other markings? Located in a recess near the brake booster there is usually a plastic cover, and 2 relay lloking devices, 1 is the horn relay the other is the intermittent wiper amp it has 7 pins in total, a bunch of 6 + 1 to the side usually has a steel mounting plate and the body (plastic) is screwed on with 4 screws. Quote
Wayne G Posted May 4, 2013 Posted May 4, 2013 Found it, but it is different to what you describe. This one has eight pin plug and part number 28890P7900; the car is 81 model. I can give you the plug and six inches of wire too if it will close the sale Quote
dat2kman Posted May 4, 2013 Posted May 4, 2013 One i parted was a 79 I have three things that all take a rectangular 6 pin plug, pladtic cover metal base, an all metal one, and other stuff. Have no dea where they were in the car. You are going to have to let us know actual measurements, what markings, and some pics of your broken one, so that a match can be sourced. Quote
imackz Posted May 5, 2013 Author Posted May 5, 2013 One i parted was a 79 I have three things that all take a rectangular 6 pin plug, pladtic cover metal base, an all metal one, and other stuff. Have no dea where they were in the car. You are going to have to let us know actual measurements, what markings, and some pics of your broken one, so that a match can be sourced. will take some pics and post them. Quote
imackz Posted May 5, 2013 Author Posted May 5, 2013 Found it, but it is different to what you describe. This one has eight pin plug and part number 28890P7900; the car is 81 model. I can give you the plug and six inches of wire too if it will close the sale not sure it is the same,(28820 -P7100 AMP-INTERMITTENT WIPER) the series 2 has a different wiper control , similar to the R31 skyline Quote
imackz Posted May 5, 2013 Author Posted May 5, 2013 One i parted was a 79 I have three things that all take a rectangular 6 pin plug, pladtic cover metal base, an all metal one, and other stuff. Have no dea where they were in the car. You are going to have to let us know actual measurements, what markings, and some pics of your broken one, so that a match can be sourced. Quote
imackz Posted May 7, 2013 Author Posted May 7, 2013 can't help with that sorry thanks anyway .. Quote
dat2kman Posted May 7, 2013 Posted May 7, 2013 Same here. It must have been left on the shell. Not everything gets removed! Maybe haunt various wrecker yards? Quote
imackz Posted May 8, 2013 Author Posted May 8, 2013 Same here. It must have been left on the shell. Not everything gets removed! Maybe haunt various wrecker yards? yes, most cars get wrecked and they go down with the sinking ship, no one removes them or the horn relays, that is why they are getting scarce. Quote
imackz Posted May 14, 2013 Author Posted May 14, 2013 If anyone is wrecking a early series 1 (1979) 280zx would like the intermittent wiper amp , nissan part # 28890-P7100 regards Iain as per below: Apparently series 2 intermittent wiper amp will also work with the series 1, if anyone has one they look similar except there is an extra pin, this is for the variable speed on the intermittent control. Quote
