thehelix112 Posted May 10, 2005 Share Posted May 10, 2005 Guys, Have any of you guys had the strut top mounts cut off and custom ones (with some form of adjustment) welded on? I'm contemplating getting Fabraications or trikfab to have a crack at it. Comments? Dave Quote Link to comment Share on other sites More sharing options...
Administrators gav240z Posted May 10, 2005 Administrators Share Posted May 10, 2005 Not sure but can't you make the lower control arms adjustable in order to change camber that way? Would be easier than cutting up the strut towers? Quote Link to comment Share on other sites More sharing options...
warrenz Posted May 10, 2005 Share Posted May 10, 2005 You can get Camber Bush Kits for the lower control arm that give you up to 1.5 degrees. As Gav says it might be easier. Warren Quote Link to comment Share on other sites More sharing options...
thehelix112 Posted May 10, 2005 Author Share Posted May 10, 2005 I need/want to be able to adjust camber/castor at the track. Unless you guys have a wheel alignment machine you care to loan me? Who makes those bush kits warren? I've seen that noltec do an adjustable one for the rear.. ? Dave Quote Link to comment Share on other sites More sharing options...
Administrators gav240z Posted May 10, 2005 Administrators Share Posted May 10, 2005 Yeah Noltec do make one for the back. You don't need a machine to do a wheel alignment. You just need string :twisted: . As Costa has shown me you can do a wheel alignment with string however you really need 2 people. He said they used to prepare the Ferrari's that way when he was working for John Bowe :lol: . Quote Link to comment Share on other sites More sharing options...
thehelix112 Posted May 10, 2005 Author Share Posted May 10, 2005 Ok so I am a lazy bugger who would rather use a block of wood and a hammer than have to jack the car up and run around with string.. Dave Quote Link to comment Share on other sites More sharing options...
Zeddophile Posted May 11, 2005 Share Posted May 11, 2005 If you want to have adjustable castor on your front wheels, what I intend to do is set up an adjustable castor rod - IE. Cut a piece out of it, and have like a tie rod kind of setup there. Land Rover Discovery Series 2 and Range Rover HSE (95 - 2001) have a male to female threaded piece (alloy) about 5 cm long in the drag link, which is used to adjust the front wheel toe in/out. Once you first set your castor up properly, you would only need to mark it then adjust the same amount of turns on either side. I am currently trying to work out the best way to adapt this for use in this situation - and also maybe for an adjustable rear strut brace, so that I don't have to spend $200 on the whiteline one. As far as camber goes, I'm thinking about it, but haven't had any revolutions yet.... Unless you could modify the mounting point for the lower control arm, in such a way it can be slid towards or away from the centre of the car..... Quote Link to comment Share on other sites More sharing options...
warrenz Posted May 11, 2005 Share Posted May 11, 2005 Not sure if you can get them in Australia but they are in the current Victoria British catalog for $75US- http://www.victoriabritish.com/ Quote Link to comment Share on other sites More sharing options...
Administrators gav240z Posted May 11, 2005 Administrators Share Posted May 11, 2005 This is what i was referring to. http://www.240z.id.au/images/car/brake_sus/lowcon.jpg For more suspension good bits. http://www.240z.id.au/Pages/suspension.htm Alot of good tips here. :twisted: Quote Link to comment Share on other sites More sharing options...
Zeddophile Posted May 12, 2005 Share Posted May 12, 2005 Thank you Gav - that is awesome, made me click onto the adjustable control arms easy as, instead of the few hours headscratching it would have taken me to work out how best to do it... you're a champ. Quote Link to comment Share on other sites More sharing options...
thehelix112 Posted May 13, 2005 Author Share Posted May 13, 2005 Changing the position of the strut-top is a much neater solution than adjusting it at the bottom. Changing it at the top doesn't affect anything else, where as at the bottom affects just about everything. So noone has done this? Or even seen it done? Dave Quote Link to comment Share on other sites More sharing options...
Natez Posted May 14, 2005 Share Posted May 14, 2005 hey dave Im looking at converting to full S13/R32 coil over suspension at the front, using some bits and peices, and custom tie rods, but its happening a slow process, as the car will be painted before any of that starts to get custom made etc.. but ive test fitted and it looks like it will work but with custom tie rods, and adjustable tension rods and not sure what control arm just yet, but most likely be from another nissan, or just a adjustable one. trying to get the proper dimensions for the actaul front subframe of a R32 to see what can fit etc, but most likely will be using stock crossmember, not sure if anyone has looked at using a R32 front end, as they are really cheap these days, also S series or R series rearnends will fit into S30s, will only some custom stuff, not sure if a victorian engineer will pass it, but in queensland they did. but i have seen struts tops on a 260z that was club reged, im sure you can get strut tops and adapt it to your struts, if you are on performance forums, (www.performanceforums.com) you can get in contact with user "lambs" im 86% sure his was the car that i saw, down in melbourne, not sure of his complete suspension setup, but it was alot of custom work at home kind of stuff, Quote Link to comment Share on other sites More sharing options...
NR240 Posted May 19, 2005 Share Posted May 19, 2005 The only method I have seen for an adjustment at the top is to drill extra holes in the strut tower on the car chassis, so you would have a few different positions with which to insert the strut into the car; or a step further is a completely modifed strut tower in the car. Regarding adjustable camber via the control arm, Gav's method is by far the smartest way I know. I went the easy option and have the adjustable control arm bush that Warren referred to. It has an Offset 19mm Hole in it which provides the movement. It makes the ride even stiffer due the fact that it has no rubber in the mount, rather a hard plastic substance, I think it is called Delron? Quote Link to comment Share on other sites More sharing options...
Mr Camouflage Posted May 26, 2005 Share Posted May 26, 2005 Don't K-mac do stuff like that? I've seen some of pics of adjustable strut tops on classiczcars. like http://www.classiczcars.com/photopost/data/500/2313CamberPlates.jpg http://www.classiczcars.com/photopost/data/500/medium/3648struttower011.jpg http://www.classiczcars.com/photopost/data/500/932struttopracing.JPG Quote Link to comment Share on other sites More sharing options...
Administrators gav240z Posted July 31, 2005 Administrators Share Posted July 31, 2005 http://www.classiczcars.com/photopost/showphoto.php?photo=14853&cat=500&page=1 this set up looks the neatest so far. Not a bad idea a fair bit of work involved though. Quote Link to comment Share on other sites More sharing options...
Administrators gav240z Posted January 15, 2006 Administrators Share Posted January 15, 2006 I just found this last night and I think it's great. http://www.betamotorsports.com/products/EMIPlates.html Not cutting things up... He's also got these http://www.betamotorsports.com/products/240StrutKit.html Costly maybe he can do discount for a kit and a group buy . Gavin pokes Sulio in the ribs probably different struts than the Tokico's to suit a standard 240z though. Quote Link to comment Share on other sites More sharing options...
thehelix112 Posted January 23, 2006 Author Share Posted January 23, 2006 Thanks for the heads up guys. I'm looking to do what Mr camouflage posted but welded on instead of bolted on. Will let you know how I go. Dave Quote Link to comment Share on other sites More sharing options...
dat260 Posted January 25, 2006 Share Posted January 25, 2006 Hi guys, I too would like adj tops but here in Canada, it would not pass inspection, not original equipment. So check this out, looks factory and adjust the same way as racing style ones. Just notch the holes a bit. Cheers, Ari http://www.zcarparts.com/store/merchant.mvc?Screen=CTGY&Category_Code=PSDC08 Quote Link to comment Share on other sites More sharing options...
