Scoota G Posted January 27, 2012 Posted January 27, 2012 As above looking for a 2 pin tps before we have to order one from the states. Quote
luvemfast Posted January 27, 2012 Posted January 27, 2012 How desperate at you Mark? I'm currently tidying up and painting the floor in the garage. But I'm sure I'd have one. Heading off to Steve's (chevZ) plac tomorrow then Wnton on Sunday. If you can wait a bit. I'll get bac to you when I can. Quote
Scoota G Posted January 28, 2012 Author Posted January 28, 2012 It's for dales car which needs to be finished for tassie! Quote
Scoota G Posted January 30, 2012 Author Posted January 30, 2012 Would be awesome if you could have a look for us Simon. Ta! Quote
luvemfast Posted January 30, 2012 Posted January 30, 2012 Got a pic of what your actually after? (To make it easier for me to spot) Any particulay throttle body it would be on? PM me your number and I'll send a pic if I find one Quote
Scoota G Posted January 30, 2012 Author Posted January 30, 2012 Got a pic of what your actually after? (To make it easier for me to spot) Any particulay throttle body it would be on? PM me your number and I'll send a pic if I find one It's the same as a 280ZX one but the one we need has only two pins. It's for a naps manifold. Quote
luvemfast Posted January 30, 2012 Posted January 30, 2012 It's the same as a 280ZX one but the one we need has only two pins. It's for a naps manifold. Hopefully the TPS is the same as I can think of 3 different types of throttle bodies. Will go out soon and check Quote
luvemfast Posted January 30, 2012 Posted January 30, 2012 I sent you some pics last night. Don't know what you mean by 2 pin type. My ones had 3 :-\ Did you get the pics? Quote
Wayne G Posted January 30, 2012 Posted January 30, 2012 Being a newbie to EFI on the L series I did some research on NAPS but only found pictures and references to a three pin tps. However, I did notice that the idle speed stepper motor only has two pins. BTW, I have two three pin TPS available. Quote
Scoota G Posted January 30, 2012 Author Posted January 30, 2012 You're gunna laugh but i tell you anyways. The MoTeC ecu i'm fitting to dale's car is a Mk1 from 1988 (I think that's when pacman came out) and as such i found little to no information on the wiring sooo i ahd wrongly assumed that the plug was for a throttle position sensor which i found out it's not. The system doesn't even run one instead it has a vacuum lead running directly to the ecu. The plug is for an air temreature sensor. Sorry for the run around guys. Quote
luvemfast Posted January 31, 2012 Posted January 31, 2012 You're gunna laugh but i tell you anyways. The MoTeC ecu i'm fitting to dale's car is a Mk1 from 1988 (I think that's when pacman came out) and as such i found little to no information on the wiring sooo i ahd wrongly assumed that the plug was for a throttle position sensor which i found out it's not. The system doesn't even run one instead it has a vacuum lead running directly to the ecu. The plug is for an air temreature sensor. Sorry for the run around guys. Bwa ha ha ha ha ha I think you can make a $10 donation to the site anyway (which is what I would have asked for anyway ) Quote
