On Saturday (which was one of the toughest days ever) where everything just went wrong "EVERYTHING" and to start with the biggest issue I really need your help in finding the correct way in fixing this.
Was at a shop changing all the bushings at the front of the car one of the bolts that connects the Sway bar to the frame broke (not uncommon, I understand), the bolt was taken out but not before the hole in the frame being destroyed (now this I don’t understand how it happened especially by a professional) and now the new bolt will not fix in anymore. Now what is the right way of fixing this?
What options do you recommend to really fix it correctly? Do I really need to cut the frame and weld in a nut from the inside? Mind you the frame is very solid. And can you recommend a place in Melbourne to do this repair as at the moment i dont have the space/tools to do any of the work myself?
