G'day Gents,
Recently took the old girl for a spin after few months in storage. Seems the carbies start to starve for fuel whenever on slopes ( some time could hear carbies popping ) However, It runs like a dream on flats.. These are the fuel set up from the previous owner : Essentially the mechanical fuel pump was replaced with in line electric pump. Both Fuel filter before fuel pump fitted top outside of fuel tank. There is no fuel line reducer on the returning fuel line. Old Fuel filter had deposit & was replaced with new one.
Question : 1) Does the carbies floats need a retune?
2) Both fuel filter & pump should be fitted at lower part of tank.?
3) Does fuel tank could use a good clean.?
Your advise are much appreciated. Thanks
