zedrally Posted September 21, 2009 Posted September 21, 2009 says it all... Anyone wreacking ATM? Quote
. Posted September 21, 2009 Posted September 21, 2009 Where are you? Also be aware that Datsun used the same handles for most models of the time. you should be able to pick something up from a wrecker. Quote
zedrally Posted September 22, 2009 Author Posted September 22, 2009 Where are you? Also be aware that Datsun used the same handles for most models of the time. you should be able to pick something up from a wrecker. In the middle of the Indian Ocean, I kid you not...the other 3 weeks in Melbourne!. I sussed that 1600 handles might be similar, anyone confirm it? Incidentally, I do mean the exterior handle, mine snapped in the white metal cast where the wire rod hooks (links) in. Thanks for the tip... Quote
Moderators Zedman240® Posted September 22, 2009 Moderators Posted September 22, 2009 Left and right handles can be swapped...cheap way out of it is if your drivers side still has both "ears" you can just swap sides. Quote
PZG302 Posted September 22, 2009 Posted September 22, 2009 From memory 1600 handles will fit and maybe 1200 and 180B, but I've had a drink and a sleep or two since I've had to worry about door handles for a Z Quote
dalee Posted September 22, 2009 Posted September 22, 2009 'Scootag' has a 180B handle on his Zed, from memory it needed only very minor modification and looks the same. Scootag........ can you confirm! Quote
zedrally Posted September 22, 2009 Author Posted September 22, 2009 Left and right handles can be swapped...cheap way out of it is if your drivers side still has both "ears" you can just swap sides. That's brilliant...thanks for all the replies.... Quote
Scando Posted September 23, 2009 Posted September 23, 2009 I have a 120Y door handle on one side of mine. It is exactly the same and required no modifications. Quote
