For sale
ported E88 with new seats inlet and exh new guides  ready for valves  will make 270hp
also 44 solex carbs better than new  this is as good as it gets for the L28
$ 4300 firm
what sort of valves and cam would you run with this set up Pete?
Would this work in a L24 block that's running L28 crank and pistons? (could be talking gibberish so correct me if that didn't make sense).
hi because of the 44mm valve size you need a 86mm bore min to work well so L28  bore ...
id run a street style cam like 70d works or a 72  so 288add 241 @50 500lift 15/46 56/15 timing
this will make power to 6 and idle nice with the carbs
