We have three new sizes of our Nemoto Mesh wheels in stock.
The 15x8 +5 will fit on a 240Z but it sits rather close to the strut.
The 16-inch sizes are suitable for a car with ZG flares if you add our 20mm spacers front and back. At $1098 total this is still a cheap option and gives loads of room for brakes. For mor info check this page: http://otomoto.shop033.com/b/2218497/1/nemoto.html
15x8 +5
4x100/114.3 PCD
Weight per wheel:  7.80kg
Backspace:  119mm
Dish:  70mm
Brake caliper clearance: 25mm from hub
$165 each
16x8 +15
4x100/110 or 4/5x114.3 PCD
Weight per wheel:  8.69kg
Backspace:  129mm
Dish:  52mm
Brake caliper clearance: 29mm from hub
$195 each
16x9 +0
Weight per wheel:  9.36kg
Backspace:  125mm
Dish:  76mm
Brake caliper clearance: 32mm from hub
$195 each
  • 2 weeks later...
Just fitted a set of our Nemoto mesh 16x8 +15 to this Z31, very nice fit
  • 1 month later...
We just got new stock of the Nemoto mesh 15x7 +20 so right now all sizes are in stock.
We also got new stock of the Nemoto Borb (Borbet replica) in 15x7 +20 and 15x8 +10 (4x100/114.3):
Another new arrival is the Nemoto Sprint, which is a 15x8 +5, available in either 4x100 or 4x114.3.
This is a very light wheel at only 6.8kg, finished in a light shade of hyperblack with polished rim:
All of the 15-inch Nemoto wheels are just $165 each.
Find them on the Nemoto page
