PZG302 Posted January 15, 2012 Posted January 15, 2012 I have for sale two alfa motorsport fibreglass bonnets, both with damage on the left front corner. One is an easy repair, the second is missing a couple of inches of the corner. Bonnets have holes and most fittings for the pins, 6 per bonnet 2 pins at the rear 2 pins at the radiatior support panel, and 2 pins at the front from the headlight buckets. These bonnets did not use any of the standard catches or hinges, just the pins to hold them on. They come in at a fairly light weight 5.7kg, a lot better than the approximate 15kg of the steel bonnets. Bonnets are to be picked up only in Brisbane and price is $100 for the both. Pictures as below, the only damage is on the front left corners. For the bonnet with the sign writing, it looks to be an easy fix as it hasn't actually broken any pieces off, if you were dodgy a bit of bog would have it looking as good as new. Quote
PZG302 Posted January 22, 2012 Author Posted January 22, 2012 No racers out ther want to save some weight and go faster? Quote
