Has anyone ever had any experience with the 280ZX digital dash? Do all plugs from the analogue dash plug straight into it? Also does anyone have any idea where to find one in Australia?
Zac
Oh I guess you want me to provide more detail.
I have one. No the plugs don't match. You could probably jimmy something up.
You can have mine for $20.
Hahah wow, that's very generous of you! I'd be more than happy to take it off your hands! :D
Only problem is, wiring is the death of me, could you elaborate on the difficulty of 'jimmy'-ing?
The plugs don't match at all. The dash only has one side of each plug (female I think). So you would either need to source the other sides of the plugs (maybe from the USA). Or you could remove the existing plugs and solder on something more familiar (eg a standard off the shelf plug or a standard 280zx plug)
I wonder whether these digital dashes were a fore runner to the "Star wars" dashes as seen in the Z31? If so maybe they share some wiring / plugs?
I had bought it with the idea to make the swap but in the end I decided it wasn't worth risking a working dash.
Hmmm fair enough. I've just had a look around and it seems you need the pigtail wiring which runs behind the dash to the main cluster in order to swap. Most people do it the opposite way, from digital to analogue, hooray for backwards engineering hey? :D Also they all have to pull their dash in order to do the wiring swap.
Nothing ventured, nothing gained though! When are you available for pick up? I have someone coming around today to check out my 260z valance and bumper but any other day would suffice!
