53-681 Posted September 22, 2011 Posted September 22, 2011 Hello everyone, I'm currently at the stage where I need to remove, test and re-condition my heater core, but am not sure on how to go about it. Currently, (If you follow my journal) my dash is off, and I beleive the heater core is somewhere close to the drivers side (judging from the hosing pipes). I have a haynes manual, but I'm not sure about which part to bolt-off to take to the radiator/heater specialist (I will be installing a new radiator, and hell I don't want all the 10year old, preserved heater core liquor flowing and having sex with the fresh coolant from the radiator) Thanx a million guys, I may have to owe you all (yet again... ) Quote
Whittie Posted September 22, 2011 Posted September 22, 2011 If you look in the engine bay of your car, from the front, on the right hand side of the brake master cyclinder, just down a little bit there are 2 pipes. These are the inlet/outlet to the heater core. The heater core is actually pretty easy to remove from the dash. I took pictures of every part of my car that I figured I needed to remember where bolts went and I didn't take one of the heater core, so I'm assuming that means it stupidly easy. The heater core itself and the 2 hoses are all that should need replacing, the rest is just air ducting around the dash. The heater core actually comes out separately and those screws that I photographed are all that need removing. Ignore the disconnecting of the flap cables YOU DON'T NEED TO DISCONNECT THEM. I did cause I'm a fool! I put all the photos I could find that seem relevant on my photobucket for you: http://smg.photobucket.com/albums/v621/Tommo560/260z%20heater%20and%20under%20dash/ Tom. Quote
53-681 Posted September 23, 2011 Author Posted September 23, 2011 Thanx a million Tom, I'll give it a go today hopefully The pics are a great help, but they're all taken from wierd angles and it took me about 5mins each for some pics to realize where the picture is of... Quote
