Hi Guys,
I really do not want to sell this stuff, so please don't buy it :(
I have collected the following over the years with a mind to put it in the 71 240Z shell i wanted to build.. circumstances changed, the shell is sold, and the early 240z that i have has matching numbers so it "may" be a shame to break that up (in my heart i want to though!).
  • R32 RB26DETT engine with forged CP pistons and ARP stud kit- professionally built by the previous owner, water pump, timing belt etc. were replaced at the time. Polished cam covers, painted blue centre cover, clear front covers. comes with twin turbo's, throttle bodies, intake manifold, wiring loom, standard computer, coil packs, CAS etc. Also comes with 2x AFM's, comes with modified front aluminimum sump for RWD (the Z's need a rear sump though)
  • RB25DET 5 speed gearbox with RB26DETT gear set and short shift kit
  • Nismo RB26DETT single plate clutch and nismo lightened flywheel
  • brand new nissan gearbox/engine mount bolts
  • Catlemain Rod Shop RB->240Z engine and gearbox mounts
what's missing
  • couple of sensor bolts (ie. cas mount bolts, ignitor bolts, knock sensor bolts, flywheel bolts
  • Injector dropping resistor
  • and of course, a modified rear sump for the 240Z
the photos attached are of the engine, can get a picture of the Gearbox over the weekend (but it looks like a gearbox) Engine is currently on an engine stand, which will go with the engine
$5500 pickup only from the hills district (gearbox alone is worth $1500)
thanks, just have to get them all into a car.. and the car going :)
The engine is sold pending payment.
