The set up consists of 300Z vented front discs (two sets) slotted with Toyota 4 pot caliper and adapter spacer. The rear is slotted 300Z disc with 180SX caliper and mounting plates. These calipers allow you to use your standard handbrake with no modifications. I have two slightly used Hawk pad sets for the front and near new Lucas pads for rear. Set-up includes steel braided lines. $500, call Andrew 08 82807607 AH or 08 82595475 work if you want more details
