Hi guys ,
Looking for a Flywheel has to be a 6 cyl L series flywheel (reason below)
Im in Carina 4152 QLD
thanks
just purchased a 200b flywheel for my L26
i have purchased an exedy 260z pressure plate and clutch combo
the problem occurred when i lined up the pressure plate to the flywheel the 260 pressure plate bolt pattern is different to the 200b one
im unsure if ill be able to redrill the flywheel to suit the pressure plate and also have the dowels relocated
as you can see no line up
advice is also welcome
thanks again people!
If all else fails I have an L28 flywheel. I actually want to keep it for myself but if you can't find a cheaper one I would sell it for $120.
This topic is now closed to further replies.
