Sorry if this has been touched on elsewhere on the forum (been looking but haven't been able to find it )
I'm looking for the wiring for the inhibitor switch ( park neutral )is in the wiring loom , I'm pretty sure the wiring is meant to be black with a yellow trace ? Due to performing a engine swap and gear box swap I think I may have left at a pervious work place many years ago  :-[
Any help or better yet pictures would be greatly appreciated
The inhibitor switch is in the auto itself, all you have to do is make a loop, and find the loom (from memory is a 4 pin plug) and just loop 2 pins (forgot which 2). There should be 2 wires for the reverse, and 4 wires for the inhibitor switch. Looms run down the drivers side of the gbox.
