Hi all,
As seen in the other topic HERE I'll be parting out the car instead after getting lots of interest for parts.
Everything bar the engine was brought brand new for the car and at most parts have maybe 300ks of use.
I'd like pick-up or delivery can be organised for South-East QLD by myself.
The smaller Items I could post at your expense but the larger items for now you'd have to organise but im happy to help on my end.
PMs are preferred or you can call/sms me on zero4seveneight118718
PICS FOUND HERE
Engine – $4500 incl all below SOLD
Approx 6500ks as it did a drive to Tassy for Targa and back to the coast before I purchased it from a mate. Made 170rwhp and 370nm of torque. Tuned by Gavin Wood. Dyno sheet available for viewing.
Hot tanked P54 Block
Bored 40 Thou. New flat top pistons & rings
N42 Cyl Head – Crack tested and machined, light head work
New bearings – Big End and Mains
Fully balanced
New Camshaft Nissan 812C 495 thou lift
New Rocker Gear & Lash Pads
New High Volume Oil Pump
New Timing Chain and Sprockets
New Adjustable Timing Gear
SW Motorsport Harmonic Balancer
New Electric Water Pump (CSR)
Fully Modified Fuel Injected Inlet Manifold
New Alloy Fuel Rail and Pressure Gauge
Enlarged Throttle Body
New Nissan R32 Injectors
Fully Balanced and Lightened Flywheel
Competition Velvet Touch Button Clutch & Pressure Plate
Extractors
2.5" exhaust
MSD Master Blaster Coil/Fully Modified Electronic Distributor
MSD 6-AL
Modified and Baffled Sump
Alloy Radiator with twin thermos
2L Surge Tank mounted in the engine bay
EF Falcon pick-up pump
Bosch 044 fuel pump
VL Turbo Starter Motor
Oil Cooler incl plate etc
Turbosmart FPR (800 series)
Driveline –
RB20DET 5-speed with 71b bellhousing to bolt straight up(fresh 0ks, just had rebuild, have receipts, comes with mounts to bolt it straight in and gearstick) $2000
R180 locked diff with 4.8 diff gears - $500
280ZX Tailshaft, will need to be cut down for the setup - $100
Suspension & Brakes –
Coilovers including hubs, bearings were all done at the same time. Brake brackets not included - $1800 SOLD
  • Ground Control Weld-On Coilover Setup
  • Eibach Springs (330lb Fronts 300lb Rears)
  • Tokico Illumina 5-way adjustable shocks
Techno Toy Front and Rear Lower Control Arms SOLD
Techno Toy Tension Control Rods SOLD
AZC Wilwood 4 pots all round (includes everything you get in the kit) - $1750 SOLD
Interior –
Racepak Digital Dash to Wolf V500 ECU (have to sell this as a package as the cable to talk to the dash only works with this ECU) $2000 SOLD
OMP Detachable Steering wheel including boss kit - $320
OMP Widebody Seat (Only a year old) - $650
OMP 3” 4point harness (only a year old) - $300
Saas Bucket Seat - $120
2” OMP Harness for passengers - $100
Full switch panels for everything - $100
240Z Dash, great condition except for where a hole was drilled in for a shift light, please see the pics. Gauges are included. - $550
Front Strut Bar - SOLD
Rear Strut Bar - SOLD
Exterior -
240 Shell with flares - $4500
Rota RBX 9.5 rears/9.0 fronts -19/-13 offsets on Fed RSR Semi’s - $1250
Alloy Rear Spoiler - $100
Modified Baffled Fuel Tank - SOLD
Thanks guys, James.
Coilover's ?
Are they 51 or 55 mm ?
Have they been sectioned ? If so by how much ?
Were the sleeves mig or Tig welded ?
Hey, they are from techno toy tuning and were put together by a professional, pretty they were tig welded because its so neat. They came withbthe perch and are 55mm iirc
Need all this stuff cleared out, open to offers and happy tomwork with you for postage etc
  • 2 weeks later...
  • 4 weeks later...
Would you be willing to ship the R180 to the USA? Zip code 91203
JW
I'll try and PM you a price today for shipping, I doubt it'll be cheap though
  • 2 months later...
Only things that are left are the following -
R180 locked diff with 4.8 diff gears (fresh) - $400
OMP Widebody Seat (Only a year old) - $450
OMP 3” 4point harness (only a year old) - $200
Saas Bucket Seat - $100
Rota RBX 9.5 rears/9.0 fronts -19/-13 offsets on Fed RSR Semi’s - $1000
240Z Dash, great condition except for where a hole was drilled in for a shift light, please see the pics. Gauges are included. - $400
Need this stuff out of the shed!
OMP Widebody Seat (Only a year old) - $350
Only have the above left, Diff is sold pending payment.
