Guys
I have a near new Wades 329 grind cam 70/30 Roaster grind for L6, used once for a dyno test, ground from a 240 A grind .
Perfect companion to the stroker crank providing truck loads of torque on  road friendly power curve
Sold with correct lash pads, fill bolts straight into a stock L series with no need to fly cut pistons
Specs are .330 lift at the rocker, .495 at the valve, 280 deg duration
Cost $440.....yours for $320 ono inc lash pads (lash pads are $180 per set for Power play)
BTW
Wades is closing up shop at the end of this month so no more local cam grinding .
PM me if interested
Alan
