What is a good transmission for a 1971 Datsun 250z with a rb26drtt engine. And what support mods do you recommend for the rb26 engine?
Just use the rb25 rwd gearbox. They are plenty strong.
Another alternative if you already have a gtr rb26 4wd box is to cut out the front drive shafts and weld up the transfer case.
As for supporting mods it depends on what your looking for. A stock rb26 with the usual bolt ons eg. Exhaust, intercooler, boost restrictor removed, ecu should get you 250rwkw easily.
Z32/33 are the same as 25 but usually cheaper
Precision 6262 work well, 20psi at 4k, more power than you'll ever be able to use in a 240
