Hi All
Below is a list of parts that are surplus to my needs. They came out of an automatic September 1971 car. PM me offers on the part(s) that you want. I would like to see them go somewhere other than sitting on a shelf in my shed. Also the parts are in Adelaide but I am willing to post.
Speedo
Tacho
LH Defrost dash vents
RH Defrost dash vents
AMP/Fuel gauge
Dash loom
Dash vent ducting L
Dash vent ducting R
Tail light RH broken reverse lens(good for someone with a broken brake light lens, to make one out of two)
Dash pad & frame(cracked but good to use as a change over when reskining/restoring your dash)
Front diff cross member
LH top door hinge
LH bottom door hinge
RH top door hinge
LH tail light panel (surface rust)
RH tail light panel (surface rust)
Automatic pedal assembly
Rear suspension uprights(vertical components that bolt to the body)
Rear suspension cross member
Moustache bar
Front castor rods
Steering column
Any questions please ask.
Greg
