z31(L) Posted August 29, 2012 Share Posted August 29, 2012 Hey, as the title says, I got an sr20de engine and gearbox package for sale. Comes with engine, loom, ecu, afm, gearbox, flywheel and clutch. It's currently in an s13, so can be seen running and tested before purchase. Once I get a deposit I'll pull it all out and have it ready to go in a couple days. The engine has ALL accessories (pwr steering pump, alternator, air-con pump etc) and can throw in a stock radiator if wanted. EDIT: Compression readings are 165-170 psi across the four on a dead cold engine, will be better on a warm test After $1200 for the lot. On southside Brisbane, can deliver anywhere in Brissy for the cost of fuel 0421 287 390 - txt or call, cheers. Quote Link to comment Share on other sites More sharing options...
