Hi guys,
I have a almost complete passenger door( minus arm rest and mirror) up for grabs. It off my 1976 260z 2+2.
apart from the amateur modifications done to house the speaker it's in OK condition.  Only some surface rust in the door cavity
The scratch on the glass is only the tint film not the actual glass. The door card is still in one piece but the speaker hole has been made bigger and then had the spacer screwed onto it using 40mm timber screws!???
Lock and handles all work fine although the exterior handle had to be adjusted(reason for the card coming off). Hinges included as well.
I also have the matching driver side card,hinges and glass(some fine scratches) but the door is scrap or if anyone needs it for panel steel.
Thinking $130 for the passenger door or nearest offer
And for the other stuff will trade for a copy of "How to Rebuild Your Nissan & Datsun OHC Engine" or some beer or $20
Gotta make room so i can rebuild my L28 so this stuff has to go(against good advice)
If you have any questions or you want to take a look let me know.
Lachlan
