Hey lads,
As some are aware im building an L28 powered hot rod (well a rat rod, but some dont get the rat rod thing)
Anyway is there a rocker cover factory that has either just "Nissan" or nothin at all that fits the L28 ???
Ive seen the rocker covers with "Nissan OHC" or "Turbo" on them
Its goin in a bonnet less rod,so the engine is for all to see
Prefer a rocker cover with nothin , then i could play "Guess what motor that is"
If theres such a piece, maybe what model it could be found on
Thanks lads
Not exactly "Z' related, but is there anywhere else L28 related ???
You can get a plain "NISSAN" one otherwise dont think theres really anything out there other then some japanese stuff (but that is big $$) can i suggest just getting a standard valve cover and grinding the top flat??
grind the lettering off then polish it up :D
+1
Proving there is enough meat there and the name isn't stamped on.
Plenty of meat , the letters are raised
Mite  just grind the "OHC" letters out
Or get a rocker cover made.....
Plenty of hemi's running around with handmade rocker covers that polish up quite nicely and look very pretty with the tig welding.
