zed240au Posted December 6, 2014 Share Posted December 6, 2014 Well after arriving at the Hillclimb in light drizzle never thought id get a my best time for the hill After driving there with 2 wheels in back and the other 2 on passenger seat I nearly didn't bother putting good rubber on in the wet so glad I did By 3rd run it was starting to dry out was happy to run in top 2 to 3in the wet and dry all day People that watch the numbers were shocked to see me matching it with Eddie Maguires Mt bulla winning Evo (and quickest car at the hillclimb) off the line to the first split So must say the new springs work for launching car feels twitchy compared to old springs but is working much better Thanks for pic hodgo Mick Quote Link to comment Share on other sites More sharing options...
zed240au Posted December 7, 2014 Share Posted December 7, 2014 video of car launching at hillclimb Quote Link to comment Share on other sites More sharing options...
Moderators PB260Z Posted December 7, 2014 Moderators Share Posted December 7, 2014 video of car launching at hillclimb Looks and sounds fantastic. Also seems to go pretty darn well to boot. Me like alot Cheers PB Quote Link to comment Share on other sites More sharing options...
bluerat Posted December 30, 2014 Author Share Posted December 30, 2014 One of Mick at the hairpin. Quote Link to comment Share on other sites More sharing options...
oldmates260z Posted December 30, 2014 Share Posted December 30, 2014 Sound great, looks even better....very nice! Quote Link to comment Share on other sites More sharing options...
620Z Posted December 30, 2014 Share Posted December 30, 2014 Yeah your car is looking great Mick. Well done on the times. Must have been a great day. Quote Link to comment Share on other sites More sharing options...
zed240au Posted January 16, 2015 Share Posted January 16, 2015 Well nearly ready for powercruise next weekend and 2 hillclimbs next month Built a new set of 1"7/8 4 into one extractors and had them ceramic coated New 243 heads fitted should lift compression from 10 to 1 to 11 to 1 New typhoon manifold fitted and 92 mm throttle body seems to go a lot harder with these mods Will check hp figures on dyno at powercruise Was thinking grill looked to big so I made a zed badge to fill the gap Quote Link to comment Share on other sites More sharing options...
zed240au Posted February 6, 2015 Share Posted February 6, 2015 With new heads manifold and throttle body got car re tuned and managed a 400.4 hp at wheels with 70hp shot of nitrous got it up to 438 hp was very happy with this result my search for power is over having broke 400 hp barrier Took car to powercruise running real well till last drag practice when I broke and cv shaft Im blaming local cv workshop as when I asked him to cut a new circlip slot in to allow cv race to move up shaft to shorten it little bit more which he said he did When I pull it apart he took circlip off and welded 3 spot welds at end of spline can see where crack starts on one of the welds Guess heated treated shaft don't like welding even I knew that not happy Now anyone out there should know how rare these z31 axles are becoming I Read a thread that Nissan pathfinder shafts have same spline so I bought couple and yes shaft has same spline so I can use z31 cv joints on shaft Joints look fine no signs of wear or abuse But shafts are 40mm short so Im thinking this is a positive as well might need a spacer but can now set shaft up with some movement not tight like it is with the z31 shafts Ill let u know how it fits up Mick Quote Link to comment Share on other sites More sharing options...
red76z Posted February 8, 2015 Share Posted February 8, 2015 The Z badge you made looks cool mate. Work well on the grill without the bump a bar. Quote Link to comment Share on other sites More sharing options...
bluerat Posted February 27, 2015 Author Share Posted February 27, 2015 Top drive last Saturday 'Hoppy', man those Ls-1 clutches must be light! If I was you, I wouldn't worry about new tyres for Barrington.... Quote Link to comment Share on other sites More sharing options...
