chev z Posted March 12, 2009 Posted March 12, 2009 When trying to upgrade front brakes I ran into some small problems , which got me thinking about [perhaps]a easier less costly alterative. Instead of using ventilated calipers would it be possible to split the ordinary 4 pot hilux calipers and widen the caliper with a spacer Quote
DevilZ Posted March 12, 2009 Posted March 12, 2009 When trying to upgrade front brakes I ran into some small problems , which got me thinking about [perhaps]a easier less costly alterative. Instead of using ventilated calipers would it be possible to split the ordinary 4 pot hilux calipers and widen the caliper with a spacer It is possible to have spacers made to widen the hilux calipers. You can also use the rotors from a R31 skyline which are vented and 22mm thick. they fit between the calipers without making them wider. I use these on my car from DBA. They are about or close to 280mm by 22mm. Quote
