As the title states, I started polishing my Wat's.
Started by sanding by hand with 180 grit sand paper, working to 1200.
Then using a die grinder with the felt attachments and Autosol as a abrassive/polishing medium.
I'm very happy with the result, but my problem is this.....
Where can I get more felt attachments from? Bunnings, Autobarns and Supercrap are useless as they only have kits with all the bits I already have. I only want the soft felt bits.
Here are some picks, before and after.
My Bunnings (Shepparton) has them, If yours doesn't then try another.
Good luck and well done so far.
Do you have a timeline for when you want your Watts fitted to the Z?
Yeah, I thought you said you got yours from Bunnings Matt. I'll check another one.
Plan is to get them on within a month or so. Got some work to do to the panels and paint first, last thing I need is overspray on freshly polished mags.
