R230 DIFF FROM TURBO 300ZX
Gordo
 Share
Hi guys, Ive been told ive got an R230 diff from a Z31 turbo. its a 4;1 ratio. i want to change the ratio to about a 3.5  If any one has one lying around or the crown and pin wheel please let me know , Thanks.
Link to comment
Share on other sites
Hey Pauly, ive since found out i have a Z32 NA ,all the NA had a 4.1. the Z32 turbos where all 3.69.
so if any one has a Z32 turbo Diff thay could part with I would be interested, cheers
Link to comment
a z32 turbo diff wont fit in your cradle mate, the diff you want to look for is a R32/R33 or S14/S15 diff (using one of these may require adapters or new axles due to being 5 bolt axels) or a Manual Z32 Na diff (normally 6 bolt). a good link can be found here that might help you https://forums.hybridz.org/topic/38251-complete-differential-list-need-help/ . the good think with the Z32 Na diff is you can get new centres for them fairly easy.
Edited by pauly_adams
Link to comment
 Share
