Millerman Posted October 12, 2020 Share Posted October 12, 2020 Hi guys just wondering if anyone has put s13 suspensions into an s30? im looking at going coilover route and have access to coilovers which are more my kind of budget but are too suit s13. i believe that you can weld the bottom to the hub assembly and then slightly modify the top to accomodate. i know if you go coilover then there is welding to be done either way... just putting the feelers out to see what others have experienced Thanks Dan Quote Link to comment Share on other sites More sharing options...
Millerman Posted October 18, 2020 Author Share Posted October 18, 2020 No one has anything to say about this? Quote Link to comment Share on other sites More sharing options...
260DET Posted October 18, 2020 Share Posted October 18, 2020 My comment is that given the increasing value of 260's doing mods just to save a few $ may not be best for the long term value of the car. Quote Link to comment Share on other sites More sharing options...
C.A.R. Posted October 19, 2020 Share Posted October 19, 2020 You can't weld an S13 spring/damper assembly to a Z stub axle/knuckle. You need to use an S13 knuckle & hub, with a hybrid S13/Z LCA. S13 strut top is too large for the Z strut tower, so an Z strut top - either OEM or aftermarket needs to be modified to fit the S13 damper rod. Whatever you do, you'll have more fabrication work then you think. I suggest you just go with lowered King springs and Z31 front dampers. Quote Link to comment Share on other sites More sharing options...
Millerman Posted October 19, 2020 Author Share Posted October 19, 2020 Thanks guys! might do it once do it right! Quote Link to comment Share on other sites More sharing options...
peter t Posted October 19, 2020 Share Posted October 19, 2020 MCA Suspension do quality coil overs for S30's. Have a choice of spring rates to go with them. 07-38655091. CBR Jeff 1 Quote Link to comment Share on other sites More sharing options...
