SiftyZ Posted July 23, 2020 Share Posted July 23, 2020 (edited) Hi, I was chasing a gearbox for a 240z if anyone had one? Edited July 23, 2020 by SiftyZ Quote Link to comment Share on other sites More sharing options...
C.A.R. Posted July 23, 2020 Share Posted July 23, 2020 12 hours ago, SiftyZ said: Hi, I was chasing a gearbox for a 240z if anyone had one? So you knew what direction it went and you've now caught it? Quote Link to comment Share on other sites More sharing options...
SiftyZ Posted July 23, 2020 Author Share Posted July 23, 2020 32 minutes ago, C.A.F. said: So you knew what direction it went and you've now caught it? Quote Link to comment Share on other sites More sharing options...
Administrators gav240z Posted July 24, 2020 Administrators Share Posted July 24, 2020 Do you want a 71a or 71b? 71b will require a bent gear lever to work with the further back gearbox hole. A 71a will fit as intended but is costly to rebuild now that parts are getting hard to find and the "monkey motion" or rifle bolt shifter required machine work repair to fix slop. There was a 71a box on eBay for an S30z. At around $700. But no driveshaft to suit (71a has a flange style shaft), 71b has a slip in yoke. Quote Link to comment Share on other sites More sharing options...
Administrators gav240z Posted July 24, 2020 Administrators Share Posted July 24, 2020 https://www.ebay.com.au/itm/133472490582 71a box. Quote Link to comment Share on other sites More sharing options...
SiftyZ Posted July 24, 2020 Author Share Posted July 24, 2020 53 minutes ago, gav240z said: https://www.ebay.com.au/itm/133472490582 71a box. Thanks Gav, did see that as a last resort for a sight unseen I just need to get the numbers off mine from the shop to confirm what mine is but I believe it’s the earlier one as the ashtray is in front of it Quote Link to comment Share on other sites More sharing options...
Administrators gav240z Posted July 24, 2020 Administrators Share Posted July 24, 2020 If you have the early console it would have come with a 71a box from factory. Later boxes can work, but will require some modifications to fit. You can also have a 71b/c hybrid box made. (This is what I did on my 72 240z) using 260z (71b) close ratios. Quote Link to comment Share on other sites More sharing options...
SiftyZ Posted July 25, 2020 Author Share Posted July 25, 2020 Thanks Again, its a 71A, ill have to look into those other options, im surprised there isnt as much as an aftermarket for gearbox parts as there is everything else on these cars Quote Link to comment Share on other sites More sharing options...
Administrators gav240z Posted July 26, 2020 Administrators Share Posted July 26, 2020 As far as I'm aware parts are readily available for 71B and C boxes. It's the 71a's that are harder to source for, but not impossible (just more expensive). They are quite a different gearbox and many owners have swapped them out over the years for later boxes due to difficulty obtaining parts. Of course with originality adding value to these cars 71a boxes are now more desired, but finding them is getting harder. Quote Link to comment Share on other sites More sharing options...
SiftyZ Posted July 26, 2020 Author Share Posted July 26, 2020 3 hours ago, gav240z said: As far as I'm aware parts are readily available for 71B and C boxes. It's the 71a's that are harder to source for, but not impossible (just more expensive). They are quite a different gearbox and many owners have swapped them out over the years for later boxes due to difficulty obtaining parts. Of course with originality adding value to these cars 71a boxes are now more desired, but finding them is getting harder. Thats where i went wrong. It has a sketchy 2nd and 3rd so iwas having it rebuilt before its booking for suspension and carbs but ive found out its stuffed and their parts aren't readily available for the '71. i dont mind chasing other options im planning on an stage 4 datsun spirit SPL build engine so im not concerned about keeping it stock. In fact ive just noticed the $4000 webers ive had built for it where its about to get tuned aren't recommended for the stage 4, guess research is key eh! gav240z 1 Quote Link to comment Share on other sites More sharing options...
CBR Jeff Posted July 26, 2020 Share Posted July 26, 2020 You should just ring Les at LCR in Warragul. He would be able to sort out your gearbox and build you an engine at the same time. It would work out a lower cost and better performance option than getting a motor from the USA. At nearly $17k Australian plus freight for a Stage 4 build from Sprint you would get a very nice jigger from Les. So many benefits to dealing with a local Australian company for items like a modified engine rather than off shore. Jeff Quote Link to comment Share on other sites More sharing options...
hmd Posted July 27, 2020 Share Posted July 27, 2020 If you are not concerned about keeping it stock. Best gearbox to use is a 71C from the S13 you will need 71B bell housing and small modification http://zhome.com/ZCMnL/tech/240SX5spd/transmission.htm Agree with Jeff about local builder. If you are in Vic, go with LCR (Les export quite a number of his build to the US) In NSW MIA engines Quote Link to comment Share on other sites More sharing options...
Administrators gav240z Posted July 27, 2020 Administrators Share Posted July 27, 2020 19 hours ago, SiftyZ said: Thats where i went wrong. It has a sketchy 2nd and 3rd so iwas having it rebuilt before its booking for suspension and carbs but ive found out its stuffed and their parts aren't readily available for the '71. i dont mind chasing other options im planning on an stage 4 datsun spirit SPL build engine so im not concerned about keeping it stock. In fact ive just noticed the $4000 webers ive had built for it where its about to get tuned aren't recommended for the stage 4, guess research is key eh! You can save yourself a lot of time hassle and money by asking the right people the right questions. Yes.. Quote Link to comment Share on other sites More sharing options...
SiftyZ Posted August 8, 2020 Author Share Posted August 8, 2020 Thanks, all. After more reading and phone calls I believe Les is by far the way to go for the build. I’ll keep you updated. Cheers gav240z and CBR Jeff 2 Quote Link to comment Share on other sites More sharing options...
