GregTas
How much rear toe in are people running at track?
My S30 used to run ~2*, under heavy braking you don't want the wheels to move to toe out so it depends a bit on how solid the rear end is.
Share this post
Link to post
Share on other sites
Thanks. So I'm doing it home and I can't measure degrees, but measured track in mm and then converted with a bit of trig. I end up with 0.6 degrees total. So sounds like I need a bit more.
Now this surprised me because when I measured the track at the front and rear of the wheels the difference in track is 5mm. This looked like it was way too much. I was thinking perhaps 2-3mm total toe in.
So just confirming I need to put more toe in on it?
Edited by GregTas
Share this post
Link to post
1mm at the wheel rim is a reasonable amount.  I run about 1mm toe in at the rear total and about 1mm out at the front per side.
Share this post
Link to post
