Magnet Posted January 8, 2013 Share Posted January 8, 2013 Just hooked up my L26 hooked to my 240z flange type gearbox and it appears that the clutch/flywheel is too thin The clutch fork hits the bellhousing before/as it starts to depress the clutch Is there any differences between 240z/260z in the gearbox/clutch area that would give this problem? Likely has a 260z clutch. Very frustrating Thanks, Ryan Quote Link to comment Share on other sites More sharing options...
Magnet Posted January 8, 2013 Author Share Posted January 8, 2013 Seems there are differences, may even be 280 clutch Does anyone know the longest thrust bearing carrier of the different models? Carrier needs to be a good 15-20mm longer to work properly Quote Link to comment Share on other sites More sharing options...
pauly_adams Posted January 8, 2013 Share Posted January 8, 2013 from memory one is 15mm longer then the other I just cant remember which is what, you will need to order a new thrust collet and bearing to suit Quote Link to comment Share on other sites More sharing options...
Moderators Zedman240® Posted January 8, 2013 Moderators Share Posted January 8, 2013 There are at least 4 (I know of) bearing carriers with different heights; try to find a zed wrecker or parts place that have several for you to compare your original and try to find a longer one. Bearing carriers and clutches are usually matched. Quote Link to comment Share on other sites More sharing options...
Magnet Posted January 9, 2013 Author Share Posted January 9, 2013 Yeah cool, tried All Zed Parts today but he might be closed atm I'll post any results I find Quote Link to comment Share on other sites More sharing options...
satrat z Posted January 10, 2013 Share Posted January 10, 2013 I had a similar problem with mine after fitting a new box and clutch, it was sorted by replacing the bearing carrier for a longer one. If you measure the one you have as a starting point, Stewart Wilkins Motorsport can supply them if you can't find them else where. Quote Link to comment Share on other sites More sharing options...
Magnet Posted January 17, 2013 Author Share Posted January 17, 2013 Sorted. Got one 10mm long, would have been nicer if it was a bit longer but was free and works so can't complain. Quote Link to comment Share on other sites More sharing options...
Daedalus-Z Posted January 22, 2013 Share Posted January 22, 2013 i had the same issue recently when I (apparently foolishly) used the carrier from the new gearbox instead of the old one. I wouldn't necessarily recommend it, but as a bit of a bodge to get the clutch to engage correctly with the shorter carrier I just made a longer push-rod for the clutch slave. Possibly not a great long term solution for the clutch, but mine was stuffed anyway, I just wanted to test the box That and I didn't fancy spending another hour doing gearbox-pushups! Quote Link to comment Share on other sites More sharing options...
C.A.R. Posted January 22, 2013 Share Posted January 22, 2013 FWIW there are 13 different height thrust bearing carriers listed on the Nissan parts database... Quote Link to comment Share on other sites More sharing options...
