datozed Posted July 17, 2011 Share Posted July 17, 2011 Hi people, can anyone advise me on what size injectors I should run in 40mm I.T.B (EFI hardware) Will be fitting them on my L28, has cam, ported-head extractors. When this motor is fully developed hoping for 200 to 220 h.p. Car is driven on the road and revved to 7000. Wanting high impedance injectors about 14 ohms or higher. Any help appreciated, thanks. Quote Link to comment Share on other sites More sharing options...
peter mc Posted July 17, 2011 Share Posted July 17, 2011 EFI hardware have the injectors for there setup, i think there 300cc injectors Quote Link to comment Share on other sites More sharing options...
Moderators Zedman240® Posted July 17, 2011 Moderators Share Posted July 17, 2011 The injectors I bought from Steve are Bosch 250cc units and work very well. I'm getting around 250ish Hp with his 45mm itb's so they should be ok for your setup. Duty cycle hardly goes over 75%. Quote Link to comment Share on other sites More sharing options...
datozed Posted July 18, 2011 Author Share Posted July 18, 2011 Thanks for the replies throttle bodies are already fitted with bosch 188 cc low impedance injectors which I believe are out of 280zx. Think these are only capable of supporting about 180 hp. So looking for an alternative high impedance injector to support 220+ hp. I think injectors out of four litre ford six might be a compatible match. I think they are high impedance bosch 21 pound but may have to change fuel rail as they are not hose-tail connection. Any thoughts on this? Quote Link to comment Share on other sites More sharing options...
PZG302 Posted July 18, 2011 Share Posted July 18, 2011 The standard 280Z injectors aren't to bad. I still use them in my race motor and there is still a bit left in them as the motor steps up a bit more in power. Currently 200hp at the wheels. Quote Link to comment Share on other sites More sharing options...
nizm0zed Posted July 19, 2011 Share Posted July 19, 2011 http://users.erols.com/srweiss/tableifc.htm Or a simplified version http://autospeed.com/cms/title_Injector-Flows/A_0102/article.html Quote Link to comment Share on other sites More sharing options...
datozed Posted July 20, 2011 Author Share Posted July 20, 2011 thanks nizmozed ill check out my injectors numbers . Quote Link to comment Share on other sites More sharing options...
nizm0zed Posted July 20, 2011 Share Posted July 20, 2011 remember when you work out your 'ideal' injector size, you should try not to exceed 80% (or there abouts) duty cycle at full power. Dont go too big though, it'll tend to make it bog down and splutter at low rpm, and you'll have trouble getting a smooth idle. Quote Link to comment Share on other sites More sharing options...
Six_Shooter Posted July 21, 2011 Share Posted July 21, 2011 When I'm at my computer I use this for reference: http://www.rceng.com/technical.aspx Quote Link to comment Share on other sites More sharing options...
dat2kman Posted July 21, 2011 Share Posted July 21, 2011 Vl commodore turbo injectors will replace the stock 280zx ones, flow approx 270 cc vs 180 cc, on stock computer it will run very rich, but play around with the signals going back to ecu fro the AFM the water temp and the air temp sensors, use variable resistors in the feeds and tune on dyne. Idle will need to be higher. I breathe through a stock single 48 mm diam tb, but it has been made bigger internally and has some mods to the way the air flows into it as well as inside the manifold. Way lease cost than a full 6 itb setup and just as fast, as some have found out! Quote Link to comment Share on other sites More sharing options...
datozed Posted July 22, 2011 Author Share Posted July 22, 2011 all ready have the throttle bodies, are vl injectors low or high impedance ?. im wanting high impedance so i can pair the injectors up 2 per driver and not use any resistors using after market ecu . thanks for the info first time doing efi Quote Link to comment Share on other sites More sharing options...
DatPilot Posted September 6, 2011 Share Posted September 6, 2011 I got my injectors from the US, 270cc '280zxt/Z31t/RB30et' units, about $300 new, set of 6. drinjectoronline or something like that Quote Link to comment Share on other sites More sharing options...
luvemfast Posted September 6, 2011 Share Posted September 6, 2011 I got my injectors from the US, 270cc '280zxt/Z31t/RB30et' units, about $300 new, set of 6. drinjectoronline or something like that Shame you didn't buy some locally for 50% more $$$ Quote Link to comment Share on other sites More sharing options...
datozed Posted September 7, 2011 Author Share Posted September 7, 2011 good deal. i still havent worked out what i need, if i tune with semi seq mode firing 3x2 injectors each injector fireing 2 shots of fuel per cycle my 180cc injectors should do the job does that sense Quote Link to comment Share on other sites More sharing options...
