C.A.R. Posted September 4, 2010 Share Posted September 4, 2010 I'm going to need this shell gone soon Matt - can you make it down here soon to remove the rear 1/4? Quote Link to comment Share on other sites More sharing options...
Bigfella Posted September 4, 2010 Author Share Posted September 4, 2010 I'm going to need this shell gone soon Matt - can you make it down here soon to remove the rear 1/4? Pm sent Quote Link to comment Share on other sites More sharing options...
Bigfella Posted September 18, 2010 Author Share Posted September 18, 2010 It has been one of those days. You know the ones, when the things you discover aren't to good. I did some serious stripping of the bus today. Only to find some not so nice rust. I already knew there was rust in the rear quarter, but there is also a fair bit in the drivers floor pan. I already have a rear quarter teed up thanks to Lurch and Rev, but know I am looking to replace the drivers floor pan and door sill as well. I need to do some serious assessing and work out whether I should just be looking out for another shell. What are the thoughts of my fellow Zedders. Thanks Matt Quote Link to comment Share on other sites More sharing options...
Bigfella Posted September 18, 2010 Author Share Posted September 18, 2010 This nearly make me forget the bad times Quote Link to comment Share on other sites More sharing options...
peter t Posted September 18, 2010 Share Posted September 18, 2010 Hey Mate, I just wish you were a bit closer as you could have my parts car shell as by your pics is a lot better than what you have got. May be it would be better to get another car and use the one you have as a parts car. My shell will go to the dump if no one wants it on a pick up basis only but it will be $0 How cheap is that. Quote Link to comment Share on other sites More sharing options...
C.A.R. Posted September 18, 2010 Share Posted September 18, 2010 Meh... I've fixed worse. What's the passenger side like Matt? Quote Link to comment Share on other sites More sharing options...
Bigfella Posted September 18, 2010 Author Share Posted September 18, 2010 So fare the passengers look A ok. I will dig deeper tomorrow! Quote Link to comment Share on other sites More sharing options...
Bigfella Posted September 25, 2010 Author Share Posted September 25, 2010 Well I guess I own to Zeds now. well one and a half. http://gallery.me.com/bigfellas/100147 I picked up half a car today to fix my roof and rear quarter. Thanks to Lurch and his dad for all the help today. Quote Link to comment Share on other sites More sharing options...
Scoota G Posted September 25, 2010 Share Posted September 25, 2010 Thats how it is ... others have to die for the chosen few to live. Quote Link to comment Share on other sites More sharing options...
Bigfella Posted September 25, 2010 Author Share Posted September 25, 2010 Thats how it is ... others have to die for the chosen few to live. I love that. Quote of the year! Quote Link to comment Share on other sites More sharing options...
oldzguy Posted September 25, 2010 Share Posted September 25, 2010 Welcome from fellow bus owner, our numbers continue to grow. I've just done a rear quarter panel replacement, not the easiest job but the finished result is so rewarding you've got the confidence to have a go at anything. Sunroof removal soon ! keep posting pics, we learn from each other, Cheers Quote Link to comment Share on other sites More sharing options...
peter t Posted September 26, 2010 Share Posted September 26, 2010 GO Bigfella GO. I've got a bus and who knows what you gonna do with the other girl when two want to go for a drive in a 2 seater. The front seat is always reserved for the cheese and kisses. Thank God for rear vision mirrors. Quote Link to comment Share on other sites More sharing options...
Bigfella Posted October 2, 2010 Author Share Posted October 2, 2010 Well today I had a crack at pulling the roof skin of the parts car. Man a lot of drilling. Came of not to bad bit hard around the corners where it joins. I will have to be much more careful on my car it is going to be harder to get it of without damaging the car underneath. The donor car had a fair bit of rust under the skin but the skin survived ok my need a couple of repairs. I hope my car is OK under the skin. Quote Link to comment Share on other sites More sharing options...
Bigfella Posted October 2, 2010 Author Share Posted October 2, 2010 I was going to have a crack at removing the rear quarter of the parts car today. It appears that this panel may not be the original on the car. Where there should be spot weld the appears to be puddle welds. I'm not sure how to go about removing them. I was thinking about removing the entire quarter including the hatch frame you know the bit that the panel is attached to. The one in my car is not so good. My only concern is that I am guessing that this is a major structural part of the car. I am not sure if it is a good idea to cut and remove it, not to mention there will be some interesting welds. What do you Zedafiles think? Quote Link to comment Share on other sites More sharing options...
Scoota G Posted October 2, 2010 Share Posted October 2, 2010 Make sure the corresponding bit with their folds and such are in the condition you require before you remove bits from your car ... Cut the bits from the parts car first and be generous with the donor so you can trim and adjust suit to your keeper. Quote Link to comment Share on other sites More sharing options...
Bigfella Posted October 2, 2010 Author Share Posted October 2, 2010 Make sure the corresponding bit with their folds and such are in the condition you require before you remove bits from your car ... Cut the bits from the parts car first and be generous with the donor so you can trim and adjust suit to your keeper. I am a bit worried about cutting my car as think this is a major structural part and the car may twist or something worse! Quote Link to comment Share on other sites More sharing options...
Brabham Posted October 2, 2010 Share Posted October 2, 2010 In that case if it is possible you may be better off replacing sections rather than the entire rear quarter panel - I always try to cut out as little of the original as possible, replacing only the rusty sections. E.g. you could do the dogleg, sill, and area under rear quarter window as separate sections. Quote Link to comment Share on other sites More sharing options...
Bigfella Posted October 3, 2010 Author Share Posted October 3, 2010 I had a very productive day today. I managed t get the roof skin of my car and remove the paint of the rear quarter. At least now I can see what stat the guard is in. Not so good, but I knew that. I think I will repair sections of the guard rather than attempting to replace the entire thing. Much of a muchness I think. Here is some Video.http://gallery.me.com/bigfellas#100155 Quote Link to comment Share on other sites More sharing options...
benny Posted October 3, 2010 Share Posted October 3, 2010 Matt, do yourself a huge favour and get some por-15 to paint all of the frame under the roof, will save any problems later on!! Ben Quote Link to comment Share on other sites More sharing options...
Bigfella Posted October 3, 2010 Author Share Posted October 3, 2010 Thanks Benny will do, Quote Link to comment Share on other sites More sharing options...
Bigfella Posted November 2, 2010 Author Share Posted November 2, 2010 Did a bit of Panel work today. It's nice to be putting some things together instead of pulling things apart all the time. I thought I would put the jigsaw back together. I got the guard off the parts car from Lurch and the missing peace when I got the trailer load of parts from Rev. Together again at last. One day it may even fid it way onto my car. Quote Link to comment Share on other sites More sharing options...
Bigfella Posted December 19, 2010 Author Share Posted December 19, 2010 I jacked the car up nice and high today to work on the drivers sill and I had a look at the chassis rails. I am still at that point of I don't no if this body is worth going on with. The chassis has had a hell of a lot of bangs over the years. If I could get new rails for a 2+2 it would really be a problem. But as far as I'm aware 2 seater ones are straight but the 2+2 follow the floor line. I am assuming that I should be able to put a straight edge on top of the rail and it should follow. Is this correct? Because it defiantly doesn't. I'm hoping I will look back at this one day and think, I don't know what I was worried about :'( Quote Link to comment Share on other sites More sharing options...
peter t Posted December 19, 2010 Share Posted December 19, 2010 Hi Mate, What is your floor like. Mine was ok but the rails were rusted out so I used a nibbler to cut off the bottom of the rails and had a channel section made a touch wider and welded on the original rails. Treated rust and painted inside rails before welding then filled up with heaps of lanolin via the compressor and degreaser gun to coat welds inside and hopefully stop further rust. Check out my build thread or give us a shout if you need more info. New rails for 2+2's from the States were to this pattern so I just got them made. Quote Link to comment Share on other sites More sharing options...
peter t Posted December 19, 2010 Share Posted December 19, 2010 A good reference site is. http://atlanticz.ca/zclub/techtips/ click on body and go to frame rail repair. You may already know this site but if not it is worth a look. Quote Link to comment Share on other sites More sharing options...
Bigfella Posted December 19, 2010 Author Share Posted December 19, 2010 Thanks Peter thats a great idea. They don't have much rust in them at all but are just banged out off shape real bad. The floor I think has come up with a few of the hits I think. Maybe a bit of gentile bit of encouragement with a sledge hammer may help. Make me feel better though hearing your idea. Quote Link to comment Share on other sites More sharing options...
