PCV valve not connected - where should the hose enter the block on an L28?
Veloce
The PCV valve on my 240z L28 (N42) has no hose connected to it. I read somewhere the hose should go into the block somewhere under the dizzy?
I had a look but couldn't see anywhere obvious where it should go? I also had a look at pictures of L28 blocks but i'm still unsure.
Can anyone help me out? I think this is something that really needs to be hooked up...
Michael
Link to comment
Share on other sites
The crank case vent is located on the left side of the block below #1 exhaust port, there should be a short tube fitted to this outlet .
You can see it here with the vent hose attached just to the right of the vacuum advance pot on the dizzy, the grey pipe with the braided hose attached running to the underside of the air box.
Link to comment
  • 3 months later...
  • 2 weeks later...
