Veloce Posted April 30, 2010 Share Posted April 30, 2010 The PCV valve on my 240z L28 (N42) has no hose connected to it. I read somewhere the hose should go into the block somewhere under the dizzy? I had a look but couldn't see anywhere obvious where it should go? I also had a look at pictures of L28 blocks but i'm still unsure. Can anyone help me out? I think this is something that really needs to be hooked up... Cheers Michael Quote Link to comment Share on other sites More sharing options...
260Coupe Posted April 30, 2010 Share Posted April 30, 2010 The crank case vent is located on the left side of the block below #1 exhaust port, there should be a short tube fitted to this outlet . You can see it here with the vent hose attached just to the right of the vacuum advance pot on the dizzy, the grey pipe with the braided hose attached running to the underside of the air box. Quote Link to comment Share on other sites More sharing options...
Veloce Posted April 30, 2010 Author Share Posted April 30, 2010 Thanks that's what i was looking for. It turns out the hose was connected but it was just going down under the car into nothing... So i cleaned out the PCV valve and hooked the hose back up. Quote Link to comment Share on other sites More sharing options...
dalee Posted April 30, 2010 Share Posted April 30, 2010 Speaking of that hose, does any one know were I can get a replacement at a reasonable price. 4 engines and they are all in a bad way. Quote Link to comment Share on other sites More sharing options...
Riceburner Posted April 30, 2010 Share Posted April 30, 2010 I got mine from Nissan, not sure how much though, but it's still in good condition 9yrs later Quote Link to comment Share on other sites More sharing options...
260Coupe Posted April 30, 2010 Share Posted April 30, 2010 Vent hose still available thru Nissan Japan ............if you know the replace part number ?? Lou Mondello sourced mine thru his Nissan contacts............give him a call 9555 9591 Quote Link to comment Share on other sites More sharing options...
Six_Shooter Posted August 5, 2010 Share Posted August 5, 2010 I used large fuel hose I purchased from an auto parts store for my PCV system. Quote Link to comment Share on other sites More sharing options...
DatPilot Posted August 5, 2010 Share Posted August 5, 2010 Im re-routing mine... turbo gets in the way. My hose is in ok nic, can send a pic if anyone wants it? Quote Link to comment Share on other sites More sharing options...
Moderators Zedman240® Posted August 5, 2010 Moderators Share Posted August 5, 2010 A Ford heater hose can also be used but it has no bends. I think its for an EF EL? It has a large opening at one end then thins out to a normal heater hose size. Quote Link to comment Share on other sites More sharing options...
DatPilot Posted August 19, 2010 Share Posted August 19, 2010 OK Im going to blank off the PCV valve connection to the efi intake manifold, has a wierd tapered thread. ANyone know what it is? and what can I blank it off with? The local bolt shops got no idea... Quote Link to comment Share on other sites More sharing options...
Scoota G Posted August 19, 2010 Share Posted August 19, 2010 Maybe the local Plumbing Hardware shop would be a better idea. Quote Link to comment Share on other sites More sharing options...
Moderators Zedman240® Posted August 19, 2010 Moderators Share Posted August 19, 2010 Find a Pirtek or Enzed shop for hose fittings. Things like that are a NPT or bizzare thread that bolt places don't really stock. Quote Link to comment Share on other sites More sharing options...
