zzzzed Posted July 4, 2009 Share Posted July 4, 2009 you could go twin charge. supercharge for down low and turbo for higher rpm. I have seen it done and the s/c had a bypass for when the turbo came on boost Quote Link to comment Share on other sites More sharing options...
Zeddophile Posted July 4, 2009 Share Posted July 4, 2009 you could go twin charge. supercharge for down low and turbo for higher rpm. I have seen it done and the s/c had a bypass for when the turbo came on boost Lancia did this on their rallying Deltas. Some other makers have done it before as well. Quote Link to comment Share on other sites More sharing options...
zzzzed Posted July 4, 2009 Share Posted July 4, 2009 I seen it done on a ca18 in a datsun 1200 Quote Link to comment Share on other sites More sharing options...
waxhead Posted July 4, 2009 Share Posted July 4, 2009 Maybe run a twin entry ballbearing turbo Boos lag is really a thing of the past nowadays with modern correctly sized turbos Quote Link to comment Share on other sites More sharing options...
Zedback Posted July 4, 2009 Share Posted July 4, 2009 SC14 supposedly bolts up to the lower mounts on a 280zx aircon bracket but needs some sort of mod to the top mounts. Could be worth looking into. My little brother had a VS commode with an SC14 that pulled hard up to 6k, so if you get the pulley dimensions right it should be fine on an L28. Quote Link to comment Share on other sites More sharing options...
Cdr Zero Posted July 5, 2009 Share Posted July 5, 2009 My brother has a supercharged AW11 with an SC14, goes pretty well. Quote Link to comment Share on other sites More sharing options...
sco_aus Posted July 5, 2009 Share Posted July 5, 2009 Yeah turbo technology has improved shit loads since people realised V8s weren't the only way to make good power. I have long wanted to SC the RB25 and have heard of it being done. I reckon with the Autronic it wouldn't be too hard, but I have spent enough money and am going to just concentrate on what I have. Sorry to hijack this a bit. The SC14 bolting to the L28 sounds promising. Quote Link to comment Share on other sites More sharing options...
chartoo Posted July 10, 2009 Share Posted July 10, 2009 there is on for sale over at hybridz. cheap buy too http://forums.hybridz.org/showthread.php?t=150347 Quote Link to comment Share on other sites More sharing options...
