260DET Posted April 3, 2019 Share Posted April 3, 2019 A couple of questions but basically how do CAMS approach the the varying requirements, on the type of event eg sprints, or, the level of of competition eg national? The specific questions are, are any specific approved/types of seats required, and, will a tinted hatch glass be OK? On the glass, new ones are not available so I'm pretty well stuck with the tinted perspex one I have. Quote Link to comment Share on other sites More sharing options...
1600dave Posted April 3, 2019 Share Posted April 3, 2019 As far as varying requirements for different categories / levels, basically you pick a category and logbook the car to that. Its then up to event organisers to decide if your car meet the requirements for whatever type of event you enter. You're not limited to entering events for what its logbooked for. My 1600 is logbooked as Gp 3 PRC (ie a rally car) despite never being used on dirt, because that was the best "fit" when I got it inspected, according to the CAMS logbook inspector. In your case, pick a category that allows the seats you have and a perspex window, even if that ends up being sports sedans or something. Quote Link to comment Share on other sites More sharing options...
260DET Posted April 3, 2019 Author Share Posted April 3, 2019 Thanks Dave, that helps. Quote Link to comment Share on other sites More sharing options...
hmd Posted April 5, 2019 Share Posted April 5, 2019 You don't need to logbook a car for sprint. There is a General Requirement for car and drivers here https://cams.com.au/regulations/manual/general-requirements I am pretty sure for sprints any seat is fine provided it's mounted correctly With tint 'have any window or windscreen fitted made from a material which is clear or, if tinted, compliant with AS 2080;' If you have a cage it probably wise to register it with CAMS because they do change their cage requirement structure from year to year. Quote Link to comment Share on other sites More sharing options...
260DET Posted April 5, 2019 Author Share Posted April 5, 2019 Thanks hmd, I thought that for sprints a car had to be road registered or logbooked so will check that out. Quote Link to comment Share on other sites More sharing options...
1600dave Posted April 5, 2019 Share Posted April 5, 2019 Depends on the level of the event. Plenty do (state supersprints / Challenge Bathurst / etc). Basic club events, not so much. Quote Link to comment Share on other sites More sharing options...
hmd Posted April 5, 2019 Share Posted April 5, 2019 Most sprints do not require logbook, may be challenge Bathurst do, Quote Link to comment Share on other sites More sharing options...
1600dave Posted April 5, 2019 Share Posted April 5, 2019 (edited) The only CAMS events you can run an unregistered and non-logbooked car are club and multi-club sprints. Challenge Bathurst, for instance, is state level so needs a logbook. Edited April 5, 2019 by 1600dave Quote Link to comment Share on other sites More sharing options...
260DET Posted April 6, 2019 Author Share Posted April 6, 2019 Thanks again Dave, I just can't find info like that on the CAMS website. Quote Link to comment Share on other sites More sharing options...
1600dave Posted April 6, 2019 Share Posted April 6, 2019 (edited) No worries, I finally obtained a CAMS Bronze Event Command qualification late last year (so I'm now qualified to act as Clerk of Course at race meetings up to State level) Part of getting the qualification was to either learn all this stuff or learn where it could be found. Was never easy to find stuff on CAMS website, they re-designed the whole website recently and made it even harder........... Edited April 6, 2019 by 1600dave Quote Link to comment Share on other sites More sharing options...
OdinZ Posted April 7, 2019 Share Posted April 7, 2019 Might be a silly question, but does those that want run in the regularity at CB don't need to be log booked do they? Quote Link to comment Share on other sites More sharing options...
24 Dat Posted April 8, 2019 Share Posted April 8, 2019 1 hour ago, OdinZ said: Might be a silly question, but does those that want run in the regularity at CB don't need to be log booked do they? Hi OdinZ, for CB the cars have to be either road registered or log booked Check out last year's Sup Regs etc at http://www.challengebathurst.com/competitor-info they have changed very little over the past couple of years, Cheers Dave OdinZ 1 Quote Link to comment Share on other sites More sharing options...
OdinZ Posted April 9, 2019 Share Posted April 9, 2019 Ah right. Good to know. Thanks Dave! Quote Link to comment Share on other sites More sharing options...
