DreamZproject
Adjust Indicator position
Hey Z brains... just wondering if anyone else finds the 240 indicator lever location annoying??? I basically have to take my hand off the wheel to reach back to the indicator!
I realise I could bend the stalk forward, but in an effort for authenticity, has anyone attached some sort of L bracket on the stalk to bring it parallel in closer to the steering wheel?
Share this post
Link to post
Share on other sites
I had the opposite problem with Nissan Compe wheel....not enough room so had to bend which wasn't a problem if done carefully.
Share this post
Link to post
Yeah, sounds like a plan if I was sure about which wheel I was going to use, but just in case I'll swap around I think a temporary measure might be best...
Share this post
Link to post
What steering wheel are you currently  running? I guess it’s not standard?
might be worth looking for an alternative wheel now instead of fiddling with the stalk. Even a standard wheel until you find the perfect wheel later.
Share this post
Link to post
It's a standard early 240Z finger-trap.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
