arbs Posted July 17, 2018 Share Posted July 17, 2018 Hi mate Im after the Drivers side rear qtr from the tail light through to wheel arch qtr window and drivers door frame. Quote Link to comment Share on other sites More sharing options...
kamarchi Posted July 17, 2018 Share Posted July 17, 2018 Anyone know if the inner guard surrounding the battery tray is the same as a 240z? Quote Link to comment Share on other sites More sharing options...
C.A.R. Posted July 17, 2018 Share Posted July 17, 2018 Yes it is. PB260Z 1 Quote Link to comment Share on other sites More sharing options...
kamarchi Posted July 17, 2018 Share Posted July 17, 2018 Awesome - Thanks Lurch Quote Link to comment Share on other sites More sharing options...
arbs Posted July 18, 2018 Share Posted July 18, 2018 19 hours ago, arbs said: Hi mate Im after the Drivers side rear qtr from the tail light through to wheel arch qtr window and drivers door frame. is this still available? Quote Link to comment Share on other sites More sharing options...
manyu Posted July 18, 2018 Author Share Posted July 18, 2018 Sorry guys, shell is gone. Most of it's been cut up and are now helping put other buses on the road. Quote Link to comment Share on other sites More sharing options...
TomC18 Posted July 18, 2018 Share Posted July 18, 2018 I know where there is another one - pretty rusty, being pulled apart currently and will be parted out after - i think the drivers side rear was rusty under the window, but the filler area appeared good Quote Link to comment Share on other sites More sharing options...
kamarchi Posted July 18, 2018 Share Posted July 18, 2018 10 minutes ago, TomC18 said: I know where there is another one - pretty rusty, being pulled apart currently and will be parted out after - i think the drivers side rear was rusty under the window, but the filler area appeared good Where? Quote Link to comment Share on other sites More sharing options...
TomC18 Posted July 19, 2018 Share Posted July 19, 2018 Moorabbin - in the mancave Quote Link to comment Share on other sites More sharing options...
kamarchi Posted July 19, 2018 Share Posted July 19, 2018 New best friend :-) seriously, would any of the following be available? 1. Battery Tray and Inner Guard (only need the section between the firewall and shock tower) 2. Left and Right Windscreen A-Pillars 3. Any section of an Inner Sill (rust repair) 4. Windscreen section between A-Pillars 5 Couple of cuts from boot floor Thanks Tom Quote Link to comment Share on other sites More sharing options...
TomC18 Posted July 19, 2018 Share Posted July 19, 2018 Will have a look on the weekend and PM you Quote Link to comment Share on other sites More sharing options...
kamarchi Posted July 19, 2018 Share Posted July 19, 2018 Thanks Tom Quote Link to comment Share on other sites More sharing options...
