  • 0
Sign in to follow this
andyk_79
How Tight Should Distributor Vacuum Advance Hoses Be ?
Question
A quick one that I haven't found an answer for through google.  How tight should the fit be for dizzy vacuum advance hoses ?  I was surprised that they slipped off relatively easily compared to say a heater hose or similar which are very tight, and thought maybe they need replacing but given I am still learning a lot of this I thought I'd better check !
Share this post
Link to post
Share on other sites
3 answers to this question
  • 0
As Cozza says,
They don't need to tight, just firm enough that they don't leak or fall off.
You should be able to remove them with a gentle pull, no need for pliers.
PB
Share this post
Link to post
  • 0
Thanks gents.  I'll spray some carb cleaner to check leaks.  Appreciated!
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
